I baught a used P8061-2 Card, which fails to connect to the PC USB Interface:
When I apply the 12V DC Power, LD12 “RUN” starts flashing and LD13 to 20 are permanently illuminated (as described).
When I plug in the USB-Cable, LD10 “POWER ON” gets on, but the PC (Windows 7 / 32 Bit) does not report an unknown USB Device to be installed.
My visual Inspection did not detect any weak points of the assembly quality. What steps could I take to fix the Problem?
For my understandingthe PIC18F2550 is controlling the USB Interface. In case this chip or the firmware is damaged, do you offer the hex-File to be reprogrammed or a pre-programmed replacement PIC controller?
Did you check this in the Device Manager?
Doesn’t the Device Manager refresh the list when you plug the USB cable to the K8061?
Maybe the USB cable is defective.
Meanwhile, I have checked all the passive components around the USB-Controller IC3 (resistors, capacitors, crystal) for correct values with no findings.
So I assume now, the USB-Chip PIC18F2550 is not working as expected. My Programmer (MiniPro TL866) accepts the PIC18F2550 to have the correct signatures, but I assume the device is protected (see screenshots made after readout).
I also checked the behaviour of the board on a second PC with the same result. Would it be possible to send me the hex Files for both processors so that I can reprogram them?
Since I am more familliar with AVR Programming, one question before I start to overwrite the PIC18F2550 contents:
When I load the HEX-File into my Programmer, I see that it modifies not only Code (Flash) Area but also EEPROM and Config Bits. In EEPROM for example I see “IC3: VK8061USB Rev: 1.3” So it ist all-in-one, and I don’t need to figure out what are the correct Config. Bits ?
Is there the K8061 device seen in the Device Manager under Other devices?
If yes, you can install the driver.
To install the driver on 64 bit Windows you have to disable the driver signature enforcement.
Please use the latest driver K8061 driver update v4.0.0.0available here.
No I tried it on XP when I bought kit and later on WIN 7 32bit and now on a new computer with WIN 10 64 bit and still the same, Windows does not see the K8061 at all an do the same as Thomas has explanation, is was by mistake I come across this forum and see that I was not the only one with the problem. If I have to bay a new and tested PIC, I would like to get the board working. I will follow the instructions on the links, but if Windows don’t pick up the device I don’t think it will work…
Strange problem, indeed.
Have you tested with other USB cable?
Have you checked all soldering, especially the USB connector and IC3?
If no help, you can return the PIC18F2550 or whole kit for inspection/repair to:
Thanks very much, I reprogram the PIC and now windows see the K8061 board, Just battling to install the driver on WIN 10, Tried om my WIN 7 Laptop, everything install, but Demo software dom’t see the K8061, will work on the at least I can see the K8061 in Device manager correctly installed.
