Output levels of K8055
I just tested my K8055 with another circuit I created. I wanted to use the digital outputs of the K8055 for switching and the PWM-signals for a buck converter which is going to drive motors. But I have still one question: What is the output-Voltage of the digital-outputs? I thought it would be 5V like the USB-Voltage, but I just got app. 1.1V out.
For the PWM-Signal I found here in the forum, that it has a frequency of 23kHz. But which voltage levels does it use?
Thanks for your help.
Tusor
There is no voltage coming out from the digital and the PWM outputs. Those are open collector outputs. You have to add there pull-up resistors.
See the thread: forum.velleman.be/viewtopic.php? … 7f798506c5
en.wikipedia.org/wiki/Open_collector
thanks for the response. I just found a newer version of the manual of the K8055. There is this problem explained much better. So I think now I know what to do.
