[quote=“peter_the_steam”]Hi There
I have added a Hobb Goblin to my extruder head and found it to be wonderful. No Jamming!!!
If you have access to a lathe, then you can put a nyloc nut in the chuck and thin it down by about 2mm. If you then do not use any of the washers that come with the kit, it will fit.
Alternatively you can print a nut from PLA with a smooth bore of about 7.9mm. This nut can then be force threaded onto the outer end of the Hobb Goblin. You will find that if you get the hobbing central to the feed hole, the hob tends to stay in the right position anyway.
The teeth of the hobbing do not cut into the filament quite the same as the old bolt, but it feeds WAY better.
Another trick I did is to put the filament holder on the LEFT side of the printer. If you manually feed some filament through the hob, then back out again, you will find that the hobbing forces the filament into an even greater curve than normal. The resulting teeth marks on the filament are then on the outside of the curve, and they will rub in the guide. If you try the same thing with the filament on the left, you will find that the filament straightens out rather than curving more. This makes it a lot smoother to feed through the guides.
Cheers
Peter[/quote]
Wow, thanks for the info as well!
I actually tried to make a thinner nyloc nut, but with the grinder and it melted the nylon right out
Also, regarding the roll position, that’s an awesome idea! I recently for the first time ran a roll way down and it was like a crazy squeaky spring going into extruder! I thought of even making a wire straightener like used all day in manufacturing to straighten prior to entering the extruder.
See here for two new hobbed bolts I made myself! Haven’t tried either yet, but can’t wait.
PROBLEM now… I was printing that rectangular pillar in semiflex/ninjaflex and it was coming out AWESOME! can barely even see layer lines and I’m @ 0.25mm!!!
- It stopped printing where you see it (I asusme my current hacked hobbed bolt is to blame.
- BUY, with the glass/heated 60 C/ glue stick topped bed, it was loose and being dragged by the head.
Is there something else that works better w/flex materials and getting to stick to the bed?
I printed that awesome tire and it stayed on…but little surface contact and material to pull / mishape while printing I guess.
