[quote=“ichbinsnur”][quote=“Meximelt”]
Cool, I since have got the print bed temp relay setup going, then failed
The relay I used couldn’t support that frequency of on/off’s. I ordered a bifurcated relay based on my brother’s recommendation as an electrical engineer. I haven’t received just yet, but hope it’ll carry the load and frequency of on/off’s when keeping the bed temp stable.
I’ll also try the sharpening like you said. I ordered e3d’s hobbed bolt and while super nice teeth, it is too short to fit stock 8200 extruder width.
Here’s what I’m waiting for now, http://www.newark.com/te-connectivity/rt31c012/relay-spst-c-o-12v-16a-bifurcated/dp/51R7375
to still get some heat to the bed so I can print your nice e3d mount w/ninjaflex extension in ABS so I don’t melt it by accident as I’ve done with others tried.
[/quote]
The relay looks good. Seems the same brand as mine (salvaged from an automation PCB), only your’s is capable of more current.
How often does it switch? My heatbed toggles only at 20-30 second intervals.
[quote]Have you installed the K8204 Z axis upgrade? I did because I’m going to also reconstruct the unstable z homing with some other things I have. Just curious how people like that upgrade. I’ll poke around and see.
[/quote]
Indeed i have, and it works quite nice, especially after my “hanging” mod. → Hanging Z axis mount for Velleman K8200/3drag with velleman K8204 Trapezoid leadscrew upgrade by Ichbinsnur - Thingiverse
I just finished to equip ,my z axis with a second one, to give it more strength. → K8200 (3drag) dual leadscrew z axis upgrade with 2 Velleman K8204 leadscrew Kits by Ichbinsnur - Thingiverse
Or look here : viewtopic.php?f=53&t=15651
Yes, it sure is! And, no, not by now. But i’m planning on designing my own, which should have some features not really available on the market right now.
At least, if any, not affordable. I also thought about getting a Vertex, but currently i have too less time and too less spare money. ;)[/quote]
OK - So I’m confident on the relay…when it finally shows up from the UK.
- Regarding the frequency of switching, I only had it working for a day or so before it killed my relay contacts. I feel as if it was more on the 5-10 sec between on/off’s but will have to see once I get that going again
- did you have a socket for your relay for the heatbed or directly solder to the contacts?
Your “hanging mod” is really cool and I’d love to try that → Hanging Z axis mount for Velleman K8200/3drag with velleman K8204 Trapezoid leadscrew upgrade by Ichbinsnur - Thingiverse
- Do you print all of your parts in ABS for the machine mods or PLA depending on where used?
I also would love to try your 2nd mount for the z axis and like the idea much better than ones running dual steppers which is not necessary
I have looked at the vertex in passing and think it’s a pretty cool machine. But with this machine, I feel as it is really truly “limitless” to the upgrades that can be done!
I have been playing with a 0.8mm nozzle on the std. e3dV6 - got a couple successful prints but for prints that start with a couple “islands” say, corners off the bed, part way up start to curl up. From there I encounter the nozzle hitting after single layer height increase (unless it starts where it just finished, but will still slam into the next “island”.
- I’m still sticking with simplify3d as I feel comfortable with it now and like the custom options with the supports, etc.
- Do you know of what may be causing my warped up corners? I am thinking I need to bring the outlines to single and only one bottom layer.
- I feel as if someone told me that there is a way to raise then lower back when going to the next point so it doesn’t lose x / y location.
- Let me know how you handle such prints in general, where it’s not a bed adhesion issue but warping “curling up” on the say 4th layer.
I greatly appreciate all of your help and answers with your experience behind them! Look forward to hearing from you and hopefully helping others who read these posts along the way
