[quote=âkuraasuâ]that (0.3 mm, 170% / 0.51 mm) can be a troublesome setting for the original 0.5 mm nozzle.
The reason is the way how Slic3r actually âdesignsâ the extrusion and calculates the volume that shall be extruded. I have noted on multiple occasions that path generation especially for infill fails when these conditions (extrusion widths just slightly above the nozzle diameter) are present[/quote]See what you mean, so Iâll start with 0.4mm layer height now.
[quote]How many layers? Can you rule out Z wobble as a possible cause for the extrusion seeming too wide? [/quote]Well, the micrometer can catch 8mm and I used them all. And yes, I have a Z-wobble. If I drive the z-axis up und down the z motor moves a bit, cause the rod is not totally straight. I saw this, but I put this back under âfine tuning, will care about this laterâ. So you can see a kind of âbandingâ. The first layers are very dense until the print reaches a height of perhaps 5 mm. Then follows a band of âlighterâ layers, again 5mm. After that again a dense band of 5 mm. Well, my cuboids have only 15 mm, so the last band is what I measured yesterday. When taking up the multiplier, the walls get more massive and the diverences disappear, only the first band is to see a bit then, perhaps the pressure in the extruder still is higher because of the bottom layers.
[quote]And rather make the part a bit bigger, so the time per layer is increased.[/quote]Will try 40x40x20 then.
[quote]You can manually stop the print after a few wall layers, in order to not waste too much filament.[/quote]Usually I let it print to the end because of the first, more massive layers. For cooling I let slow down if the layer printing times is below 30s, minimum speed is set to 10 mm/s, which appears to be really slow.
[quote]Also check the temperature setting (thermistor placed correctly?),[/quote]Because I was not so happy with my capability to place the thermistor in its hole, I wrapped a layer of PTFE-tape around the heating block, holding the thermistor tightly at its place perhaps. Worked very good for me.
[quote] also try to âcalibrateâ the extrusion temperature for your orange filament.[/quote]OK, so my hot-end is clean now, I switch back to the black Veleman filament, from which I still have have a spool here.
[quote]PS: which region in Germany are you in?[/quote] Frankfurt am Main
I burned every rest of filament in the nozzle and the metal tubing. Trying the ultra sonic to get rid of the rest of the coal didânt work. I scratched ou the burned residues with a piece of wood and filament string, until everything was clean. The 0.5 mm gauge still didnât fit through the nozzle, perhaps it was too cheap?
Printer is heating up now, I will run over to my neighbour and see if I can get a digital calliper.
Will report soon
walo
