after several printing the motors are not moving anymore…LED is not on as well. I changed all drivers with new once but even this doesnt work. Only the fan I can start as well all heatings.
Any idea? Is it the board or are all 3 motors defect? How can I check board or motors?
Thank you!
Andreas
At first, check the 15v supply.
If that is ok remove all motor connections and try to connect the printer in repetier
Does that work without any error messages in the log?
I checked 15V and 5V - they are working.
I checked communication - I can start heatbed heating and nozzle heating without any problem.
I checked nozzle ventilator - it can be controlled by switching it on and off manually.
I measured stepper motors resistance - low resistance on pin 1–2 and 3–4, high between 2–3 (seams to be ok).
but I’m still not get the stepper motors to move. Remember, it worked for several month already and I also changed meanwhile the polo boards (incl. voltage check and adjustment 0.4xx).
Any idea what to check further more?
Thank you!!
Below the send/receive messages while printing and while manual move (but motors are not moving even that they are attached)
Send: N29603 G0 F6000 X115.445 Y89.565113
Recv: ok
Send: N29604 G1 F3000 X112.198 Y86.317 E1602.512576
Recv: ok
Send: N29605 G0 F6000 X112.154 Y84.577123
Recv: ok
Send: N29606 G1 F3000 X109.863 Y82.286 E1602.5887513
Recv: ok
Send: N29607 G0 F6000 X113.221 Y89.887118
Recv: ok
Send: N29608 G1 F3000 X113.481 Y90.570 E1602.6007811
Recv: ok
Send: N29609 G1 X113.566 Y91.504 E1602.61246107
Recv: ok
Send: N29610 G1 X113.566 Y92.352 E1602.6234097
Recv: ok
Send: N29611 G1 X113.566 Y93.201 E1602.6343499
Recv: ok
Send: N29612 G1 X113.566 Y94.050 E1602.64526100
Recv: ok
Send: N29613 G1 X113.566 Y94.898 E1602.65619103
Recv: ok
Send: N29614 G1 X113.566 Y95.747 E1602.66710103
Recv: ok
Send: N29615 G1 X113.566 Y96.595 E1602.6780499
Recv: ok
Send: N29616 G1 X113.540 Y97.418 E1602.68897100
Recv: ok
Send: N29617 G1 X113.434 Y98.161 E1602.69839102
Recv: ok
Send: N29618 G1 X113.257 Y98.832 E1602.70722104
Recv: ok
Send: N29619 G1 X112.996 Y99.419 E1602.71558100
Recv: ok
Send: N29620 G1 X112.969 Y99.817 E1602.72496108
Recv: ok
Send: N29621 G0 F6000 X113.035 Y94.458119
Recv: ok
Send: N29622 G0 X101.942 Y93.90025
Recv: ok
Send: N29623 G0 X101.385 Y86.88828
Recv: ok
Send: N29624 G0 X99.671 Y86.51932
Recv: ok
Send: N29625 G1 F3000 X99.082 Y86.354 E1602.7358962
Recv: ok
Send: N29626 G1 X98.233 Y86.354 E1602.7468488
Recv: ok
Send: N29627 G1 X97.385 Y86.354 E1602.7577786
Recv: ok
Send: N29628 G1 X96.536 Y86.354 E1602.7687295
Recv: ok
Send: N29629 G1 X95.688 Y86.354 E1602.7796593
Recv: ok
Send: N29630 G1 X94.839 Y86.354 E1602.7906082
Recv: ok
Send: N29631 G1 X94.053 Y86.416 E1602.8005586
Recv: ok
Send: N29632 G1 X93.329 Y86.541 E1602.8092185
Recv: ok
Send: N29633 G1 X92.687 Y86.747 E1602.8175493
Recv: ok
Send: N29634 G1 X92.015 Y86.924 E1602.8258480
Recv: ok
Send: N29635 G1 X91.739 Y87.496 E1602.8331480
Recv: ok
Send: N29636 G1 X91.052 Y87.658 E1602.8412190
Recv: ok
Send: N29637 G1 X90.892 Y88.346 E1602.8492785
Recv: ok
Send: N29638 G1 X90.320 Y88.623 E1602.8566990
Recv: ok
Send: N29639 G1 X90.145 Y89.296 E1602.8650393
Recv: ok
Send: N29640 G1 X89.934 Y89.934 E1602.8735483
Recv: ok
Send: N29641 G1 X89.816 Y90.665 E1602.8828582
Recv: ok
Send: N29642 G1 X89.758 Y91.455 E1602.8930089
Recv: ok
Send: N29643 G1 X89.758 Y92.304 E1602.9039188
Recv: ok
Send: N29644 G1 X89.759 Y93.153 E1602.9148390
Recv: ok
Send: N29645 G1 X89.759 Y94.001 E1602.9256992
Recv: ok
Send: N29646 G1 X89.760 Y94.851 E1602.9366990
Recv: ok
Send: N29647 G1 X89.760 Y95.699 E1602.9476986
Recv: ok
Send: N29648 G1 X89.759 Y96.548 E1602.9586795
Recv: ok
Send: N29649 G1 X89.799 Y97.436 E1602.9696789
Recv: ok
Send: N29650 G1 X90.049 Y98.110 E1602.9865880
Recv: ok
Send: N29651 G1 F2400 E1598.4865856
Recv: ok
Send: N29652 G0 F6000 X94.000 Y92.54976
Recv: ok
Send: N29653 G1 F2400 E1602.9865855
Recv: ok
Send: N29654 G1 F3000 X94.000 Y88.328 E1603.0858361
Recv: ok
Send: N29655 G1 F2400 E1598.5858356
Recv: ok
Send: N29656 G0 F6000 X98.000 Y88.23878
Recv: ok
Send: N29657 G1 F2400 E1603.0858362
Recv: ok
Send: N29658 G1 F3000 X98.000 Y92.549 E1603.1871955
Recv: ok
Send: N29659 G1 F2400 E1598.6871954
Recv: ok
Send: N29660 G0 F6000 X98.000 Y95.80979
Recv: ok
Send: N29661 G1 F2400 E1603.1871959
Recv: ok
Send: N29662 G1 F3000 X98.000 Y100.009 E1603.285950
Recv: ok
Send: N29663 G0 F6000 X98.000 Y99.81965
Recv: ok
Send: N29664 G0 X94.000 Y99.81942
Recv: ok
Send: N29665 G0 X94.000 Y100.00919
Recv: ok
Send: N29666 G1 F3000 X94.000 Y95.809 E1603.3847054
Recv: ok
Send: N29667 G1 F2400 E1598.8847057
Recv: ok
Send: N29668 G0 F6000 X106.000 Y95.809113
Recv: ok
Send: N29669 G1 F2400 E1603.3847061
Recv: ok
Send: N29670 G1 F3000 X106.000 Y100.009 E1603.4834659
Recv: ok
Send: N29671 G0 F6000 X106.000 Y99.819116
Recv: ok
Send: N29672 G0 X109.867 Y99.80730
Recv: ok
Send: N29673 G0 X110.000 Y99.94230
Recv: ok
Send: N29674 G1 F3000 X110.000 Y95.809 E1603.5806415
Recv: ok
Send: N29675 G1 F2400 E1599.0806450
Recv: ok
Send: N29676 G0 F6000 X110.000 Y92.549119
Recv: ok
Send: N29677 G1 F2400 E1603.5806453
Recv: ok
Send: N29678 G1 F3000 X110.000 Y88.543 E1603.6748313
Recv: ok
Send: N29679 G0 F6000 X109.913 Y88.713125
Recv: ok
Send: N29680 G0 X105.999 Y88.42717
Recv: ok
Send: N29681 G0 X106.000 Y88.23818
Recv: ok
Send: N29682 G1 F3000 X106.000 Y92.549 E1603.776204
Recv: ok
Send: N29683 G0 F6000 X106.000 Y93.859 Z26.05018
Recv: ok
Send: N29684 G0 X101.942 Y93.90021
Changing monitoring state from ‘Printing’ to ‘Paused’
Recv: ok
Send: M105
Recv: ok T:191.1 /190.0 B:57.8 /58.0 @:0 B@:128
Send: M105
Recv: ok T:191.1 /190.0 B:57.9 /58.0 @:0 B@:128
Send: M105
Recv: ok T:190.5 /190.0 B:58.0 /58.0 @:19 B@:128
Send: M105
Recv: ok T:189.4 /190.0 B:58.0 /58.0 @:108 B@:128
Send: M105
Recv: ok T:188.6 /190.0 B:58.0 /58.0 @:128 B@:128
Changing monitoring state from ‘Paused’ to ‘Operational’
Send: M84
Send: M104 T0 S0
Send: M140 S0
Send: M106 S0
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Send: M105
Recv: ok T:190.1 /0.0 B:58.0 /0.0 @:0 B@:0
Send: M105
Recv: ok T:191.1 /0.0 B:58.0 /0.0 @:0 B@:0
Send: M105
Send: G91
Send: G1 Y-1.0000 F1000
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G1 X-1.0000 F1000
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G1 Y1.0000 F1000
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-1.0000 F150
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G1 Z1.0000 F150
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: M105
Recv: ok T:185.0 /0.0 B:57.5 /0.0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 E5 F100
Send: G90
Recv: ok
Recv: ok
Send: M105
Recv: ok T:182.7 /0.0 B:57.3 /0.0 @:0 B@:0
Send: M18
Recv: ok
Send: M106
Recv: ok
Send: M18
Recv: ok
Send: M106 S0
Recv: ok
Send: M105
Recv: ok T:178.5 /0.0 B:56.9 /0.0 @:0 B@:0
Send: M105
Recv: ok T:177.0 /0.0 B:56.7 /0.0 @:0 B@:0
Send: M105
Recv: ok T:175.9 /0.0 B:56.7 /0.0 @:0 B@:0
Send: M105
Recv: ok T:174.4 /0.0 B:56.5 /0.0 @:0 B@:0
Send: M105
Recv: ok T:173.2 /0.0 B:56.5 /0.0 @:0 B@:0
Send: M105
Recv: ok T:171.8 /0.0 B:56.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:170.4 /0.0 B:56.3 /0.0 @:0 B@:0
Send: M105
Just a guess, did you change the firmware?
I updated the firmware as well just to see if the board is still running…
As it works beside moving the step motors…any further idea?
The firmware update might be the cause of the trouble.
Did you use Arduino Version 1.0.6 to compile and flash it?
If you used any higher version that might cause strange behaviour due to some library issues in the newer arduino versions.
thank you for your constant support.
Yes, I used 1.0.6 for updating. Please note that it even didn’t worked before the update. I just did it to overwrite possible software issues.
Seams I have to buy a new board… maybe check if it still has some guarantee…
Regards,
Andreas
Do i get you right?
ALL motors don’t move?
Does any motor have noticable torque when powered?
Check the screws at the blue connector on the board.
Make sure they are tight.
Remember these machine vibrate a lot they could have come loose.
[quote=“Wrong Way”]Check the screws at the blue connector on the board.
Remember these machine vibrate a lot they could have come loose.[/quote]
Also a good point!
On my machine the whle svrew terminal came loose due to bad solder joints on the controller pcb.
I started the printing job…bed and hotend getting hot and after reaching the target values I can see the moving commands but still the motors are without power. Easy to move. So, X-,Y-, Z- and extruder motor are without power. Only ventilator could be started.
Checked the input voltage…as well during the process just a little above 15V (screws are fixed).
Thank you!
What Voltage do you measure on the input terminals of the stepper drivers (Vmot pin)?
Well, quite strange.
The driver boards get sufficient power and no movement at all?
Are there any error messages in the repetier log when you try to move the motors?
Like brownout, mintemp, maxtemp or error 999?
Can you post a complete log from conneting the printer in repetier to manual motor movents?
Is this the right log, I’m using OctoPi:
(Extruder wasn’t heated)
Send: M105
Recv: ok T:23.9 /0.0 B:24.5 /0.0 @:0 B@:0
Send: M105
Recv: ok T:23.8 /0.0 B:24.5 /0.0 @:0 B@:0
Send: M105
Recv: ok T:23.6 /0.0 B:24.5 /0.0 @:0 B@:0
Send: M105
Send: G91
Send: G1 Z-10.0000 F150
Recv: ok
Recv: ok
Send: G90
Recv: echo: cold extrusion prevented
Recv: ok
Send: M105
Send: G91
Send: G1 X-10.0000 F1000
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G1 Y-10.0000 F1000
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G1 X10.0000 F1000
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Send: G1 Y10.0000 F1000
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: M106
Recv: ok
Send: M105
Send: M105
Send: M105
Send: M105
Send: M106 S0
Recv: ok
Send: G91
Send: G90
Recv: ok
Recv: ok
Recv: ok
Send: G91
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G28 X0 Y0
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G28 Z0
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: M105
Send: M105
Send: M105
Looks like everything is ok in the log.
Can you try to connect the printer to your PC directly and monitor what is does then?
Do the red Led’s next to the stepper drivers light up (flash) when you try to move the motors?
I didn’t checked with the PC yet.
The LEDs are not flashing when trying to move motors.
If the LEDs don’t flash the stepper drivers get no stepping signal.
Try connecting the printer directly to a pc to see what happens then.
This might be a firmware issue.
Which firmware does your machine currently run?
I used the firmware installed from the beginning were it operated. After starting of the problems I had a firmware issue in mind as well and updated to FIRMWARE K8200 MARLIN V2. But dosn’t worked either.
Should I test and go back to Merlin V1?
With connecting to PC directly do you mean using Reptier??
[quote=“Andre_HD”]I used the firmware installed from the beginning were it operated. After starting of the problems I had a firmware issue in mind as well and updated to FIRMWARE K8200 MARLIN V2. But dosn’t worked either.
[/quote]
That might be the issue. Did you pay attention to use Arduino Version 1.0.6 to flash the new firmware? → arduino.cc/download.php?f=/arduino-1.0.6-windows.exe
Using any newer version will lead to unpredictable results, as it doesn’t compile the velleman firmware versions correctly.
[quote]Should I test and go back to Merlin V1?
[/quote]
If you don’t have the LCD mounted this might be worth a try. I’m not sure if the LCD capable firmware will work withot LCD mounted.
But AFAIK it normally “should” work.
Yes, try the latest repetier host from here : repetier.com/downloads
Just to sort out problems with octopi.
