Thanks for the answers …
the resistances I had also checked with the multimeter but correspond to the instructions.
Regarding the jumper (or shunts) I will try to turn them … but the instructions and the screen printing are indicated as I placed them (you can also see from the picture - my circuit is the one with the heatsink)
however, the shipping of the circuit would cost more than the circuit itself … beyond the times that obviously lengthen a lot.
Is it not possible to have some more information or an indication of what the problem might be, so that I can check?
I’m an electronic expert even if I do not have an oscilloscope, I could do some control.
It would be possible ???
Thank you
Without power supply, without jumpers, pins 4 and 5 are NOT grounded. Do I also have to check the voltage of these two pins by supplying the circuit to 12V?
Is there a simple way, by means of an inter-switch, to exclude the operation of the circuit returning to the standard functionality of the stop?
Or is the only method to completely disconnect positive input and output by connecting them together?
(this function is very important for the annual review of the vehicle)
Connecting a dual pole switch means having to connect 6 wires lengthening them up to a comfortable point where to place the switch. This is complicated. There is no solution with a single pole connected to the positive pole or to the negative pole only?
I will repeat the measurements with a live circuit.
