How to set up Cura?
[quote]
If you use the stock hotend you will have to change the nozzle size back to 0.5mm.
Also the temp setting can be about 10-15°C lower.
The temp, filament diameter and flow rate need to be set based on your filament.
Stops in print can have much different causes.
Interference from switching TL lights, USB cable near power lines, Power issues, heat…
I don’t think the board istelf overheats, but maybe the stepper drivers?
Check if they are all set to 0.55V.
Are there any hot parts on the board?[/quote]
I have the stock nozle yes.
The temperature i setted are 190 for extruder and 50 for the heated bad, I just wonder if higher temperature can make a little better job.
My filament is the standard 3mm so… no idea what are the right settings… the flow i believe was 100 mm/s as standard…
Tl Lights?Whats that? I dont have power lines near the cable. Power issue no because my comp works fine.
I was guessing Heat, and the motherboard sometimes can be hot, but I cant judge if is too much honestly.
What are the stepper drivers?
All the chip for the motors are set to 0.55 V as mentioned on the instructions.
After i used your settings i noticed that when you lunch the print the extruder rise up to 0.15 mm I believe, Never done it before i wonder how can i move it back close to the bed.
Is it intended?
Thx in advance and sorry for the many questions. :V
