How to set up Cura?
Hi, im very new to 3D printers, how do i upload the attached the above settings into Cura??
What ultimaker printer should i select??
Is there a way to put the curaengine into repetier as I watched a video how to finish a product from repetier website and they select curaengine rather than slicr which would make it very easy to use? I’m new to 3d printing so any help most appreciated
Also was interested why they show curaengine but it does not come in the package like slicr does would mean they think curaengine is better?
Hi.
Both slic3r and cura engine have it’s andavtages and disatvantages.
Cura engine is way faster than slic3r wheras slic3r has more settings available to tweak to overcome som problems.
If you get the recent repetier host version from here :
repetier.com/downloads
There is cure engine and slic3r included and both will be installes with repetier host, so you can then choose.
cheers,
Christian
Can you reupload the settings? :slight_smile:
Can someone please upload the CURA settings again? they are deleted
