Hello All,
I’m new to this forum, but am glad to see that there are people to help me!
A while ago I bought a R/C car from a local thrift store for $5. I then bought a battery for it, and tested the motor’s functionality. Everything on the R/C car is working great.
The best part about the car is it has a Realtek RX2/TX2 chip motor controller, which means I can send small amounts of voltage directly to the appropriate pins, and control the motors for the R/C car for the functions: Forward,Backward,Left,Right.
What I have done is soldered wires directly to the associated pins on the RX2/TX2 controller. When I use a AA (1.5V) battery, and connect the associat works ced pin to the GND of the controller, the car’s functionorrectly.
I have a K8055 Experiential card. What I’d like to do is control the car functions from the 4 of the 8 digital outputs for the functions mentioned above. To do this, I’ve read that I need to provide an external power source to the 4 of the 8 digital outputs. Since I know a single AA battery is enough voltage to fire the function on the R/C board, I want to use this as an external power source.
My question is. How would I wire this? I need to somehow have the battery be an external power source, and then make it when I set the digital output’s 1-4 to on, it sends the power through the battery and send the voltage to each cable wired to the R/C car.
Thanks in advance for your help!
-CoffeeKid
