Air bubbles ? Bulles d'air?
I use my K8200 since 7 months, now I have problems when printing, i have some air bubbles ? I think extruding is not regular ?
Why you think about that ?
J’utilise ma k8200 depuis 7 mois, depuis quelque-temps j’ai des soucis d’impression, la dépose de PLA ne se fait pas régulièrement, au final, cela donne comme des bulles d’airs dans la pièce finie !
Quelqu’un à une idée ?
Merci d’avance
What did you change recently?
You should take a closer look at what happens during printing
It sort of looks like you maybe running the extruder a little hot.
For PLA try 190C
@Wrong Way : Temperature is set to 185°C
@VEL448 : When I print, the flow stop a fraction of second ! But the extruder wheel is rotating normally.
Hi jivens,
you could check if your extruder thermistor is still at the right place with good contact to the the heating block. I had the same issue with my printings and rearranging the thermistor and fixing it with some aditional tape did the job.
If the thermistors looses contact to the block, perhpas because of the vibrations of the printer, then the readings are to low.
regards
walo
Hi Walo,
Sorry for late return, I was in Holidays.
I check the thermistor and it’s ok, I use kapton tape to ensure the thermistor.
Have you another idea ?
Regards.
Already checked the transportation screw? Perhaps it’s not clean, residue of PLA in the gaps of the screw could cause slip.
Another point is the PLA itself. It can absorb moisture from the air, if humidity is going up or temperature is dropping.
Regards
walo
Have you tried to adjust the reference voltage to 0.55
Hi, all, I’ve finally found the problem !
This is the teflon tube ! with the time, the tube is deforming under the temperature ! I print only in PLA.
up diameter : 16.4mm
down diameter (where’s the screw) : 17.4mm
Where can i buy some those teflon tube ?
Thanks in advance
Hello, j’ai trouvé d’où vient le problème. c’est le tube en teflon qui c’est déformé sous la chaleur. j’imprime uniquement avec du pla.
Le diamètre du haut : 16.4mm
Le diamètre du bas 17.4mm.
Le diamètre intérieur se modifie de presque autant et le filament commence à fondre dans le guide teflon ce qui fait de petit bourrage !
Où peut-on acheter de ces petits tubes teflon ?.
Merci d’avance à tous !
The photo of the deformed teflon tube :
Mind deformed the same, except mine split where the threads met the body as well so I had PLA oozing out.
As far as I know you have to buy it as part of the extruder kit http://www.velleman.eu/products/view/?id=415792 but the price is ridiculous.
I have access to a lathe though, so I bought a 500mm length of PTFE rod and turned some up for myself.
Maybe Velleman will give you one as you only need the one part? Worth a try.
We’d be happy to replace it if you return it for inspection, but please check you assembly and temperatures, since it is highly unusual that this part deforms.
Bonjour,
j’ai effectivement contrôler les températures (avec d’autres sondes thermocouple, PT 1000 et Laser), tout est ok.
La seule chose particulière, j’ai effectué des impressions de longue durée et en série :
1x 32H , et 5x 19H.
La température d’impression était de 190°C.
Je vous retourne uniquement les pièces en téflon ?
A quelle adresse ?
Est-il possible d’en commander en plus ?
Merci d’avance
Hello there,
I actually control temperatures (with other thermocouple probes, PT 1000 and Laser), everything is ok.
The only special thing I did impressions of long-term series:
1x 32H and 5x 19H .
The print temperature was 190 ° C.
I return you only the parts Teflon?
To which address?
Is it possible to order more?
Thank you in advance
jivens,
si vous êtes sur Paris je peux vous donner une pièce teflon, j’en ai plusieurs, donc je peux vous dépanner si vous le souhaitez ?
Please return it to:
Velleman Projects SAV
Legen Heirweg 33
9890 Gavere
Belgique.
Make sure to include a copy of this conversation.
You can order it as a spare part.
Order code: EXT8200FG.
Sorry, we do not sell direct.
Please check pricing and availablility with your Velleman distributor.
@Tag :
Merci, pour votre proposition, mais j’habite à 600km de Paris.
J’ai posé la question à mon fournisseur habituel afin de voir si il peut me vendre cette pièce : EXT8200FG
Personnellement, je n’ai rien trouvé sur le net avec cet Order Code.
C’est normal que vous n’avez rien trouvé sur le net.
Ce composant à été crée le 25/8/2014
Votre distributeur Velleman doit le commander pour vous.
@VEL417 : L’art. EXT8200FG contient les deux parties en téflon ? J’ai reçu l’offre financière de mon fournisseur.
pourais-tu nous dire le prix car j’ai le même problème et je suis tres tenté d’installer un ED3 V6 sauf si le prix de la piece en téflon est d’un prix dérisoire.
merci d’avance
Pour ma part, j’ai opter pour la E3D v6, car son prix est inférieur au tarif de celle d’origine (complète) et bien mieux adaptée aux températures élevées pour l’utilisation de l’ABS.
En plus il y a un plus grand choix de taille de buse.
