"6 command waiting" on connection
Hello all
Maybe you could enlight me :
I can connect to my printer but i’m unable tu use it unless a it the reset buton on the board.
On connection with repetier V0.95F it display “6 command waiting” and will increase the number if i try to do something with the manual controls.
This problem occure with de velleman alimentation or my new one (i’ve seen on this forum that could be the source of the problem).
It would be usefull for me not to have to do the manual reset, because i use some remote control on my conputer tu start the printings when i’m not home.
Thank you for your help.
(don’t pay too much attention to my english, it’s rusty, i’m french)
Hi hirodan,
in Repetier Host’s Printer Settings, make sure “Reset on Connect” is set to Disabled and the Baud Rate is correct (250000).
If this does not fix your error, check the power supply. The controller board needs both, USB power (for the FTDI chip) and main power (for the ATmega), to communicate with the computer.
Cheers,
kuraasu
Many thanks !
Damned option !
Works fine now !
Hi hirodan
I had the same issue.
Connection kept failing.
Setting the option worked fine!
Rainer
