nice screw, printed with 50%. Height 150mm.
you can also see the Y-Axis Belt tensioner at the bottom.
Nice! Mind sharing the .stl file, I’d like to try to screw… seems quiet interesting!
Didi you print the whole lenght without brim ?!
Hello can you post your adjustment.
Its look very great.
i did these things to enhance the printer:
carefully build the Y/X Plattform > double check for smooth travel!
Can you say bed temperature, extruder temperature and your layer height ?
Because I tried to print the long screw but after 2cm, the screw stick the extruder.
My config is :
bed temperature 55 °C with Mirror
extruder temperature 205 °C
first layer height : 0.30mm
other layer height : 0.15mm
thanks in advance
bed temperature: 55 °C with mirror
extruder temperature: 190 °C (Printspeed 50%)
other layer height : 0.25mm
if your extruder hits the screw your table is not flat.
i leveled the table with a dial gauge like this to 1/100mm
the mirror is just taped to the underground, with 4 screws i was not able to get a level surface.
with this configuration is working fine
But I want to understand why is not possible with a layer height to 0.15mm
check with a dial gauge if the z-axis moves correctly, e.g. 0.15mm / 24 Steps. if the nozzle hit something then its too low.
Hi Thev
Realy good indeed. I was wondering what filament you where using. If I see your picture there semms to be absolutly no fine extruded pieces between the mulitple parts. How come? If I print I allways get those when the extruder changes to the next piece.
Or did you modify the slicer settings somehow?
best regards,
Christian
there are fine strings from travel between the pieces. you can see them in the long screw in the lower part.
Hi
I see, but still you get much less then I do.
Best regards,
Christian
My retract Settings:
lenght: 3mm
Speed: 65mm/s
Extra Lenght on Restart: 0.1mm
Retract on Layer change: yes
be sure to check the gear distance. i have almost no clearance.
Thanks for the hint I will try it.
But first I need fix my printerconnection.
Wow, this it he print quality I want to achieve. I’ll try out your suggestions.
Hi
it is very very good result
it is PLA or ABS ?
i am very far of this result, could you say your adjustment
Regards
I printed this with PLA. Check my earlier Post to see my modifications.
[quote=“thev”]nice screw, printed with 50%. Height 150mm.
[/quote]
Ok, i saw your modifications
You said printed with 50 %; but 50 % of what ?
and could you give me your slic3r setup ?
[quote=“maxdgdg”][quote=“thev”]nice screw, printed with 50%. Height 150mm.
[/quote]
Thanks[/quote]
Please can also have yt slic3r setup ? Can you publish it here pls ?
