Z-motor suddenly stopped working
I have been using the k8400 for a while now and i am really happy with it, making better prints each time!
But when my printer finished a print yesterday, my Z-axis(motor) suddenly stopped working. When i “home” it. my X & Y axis do as normal, but when the Z axis should go up and down, the printer just stops. After that in the interface the option “controlprinter” is gone. I already tried to replug the motor, but that didnt seem to work.
Does someone have an idea whats going on? (before i start unscrewing parts :P)
Thank you for your time helping me out :slight_smile:
did you check the z-axis endstop? Maybe oil or debris is blocking the lightsensor
Actually… no :blush: I will check it after my work. Thank you for your fast reply! I will post an update this afternoon.
So the endstop was clean and triggers when i test it. But my z axis is still doing nothing.
But when i trigger the endstop and then “home” it. It starts making a noise from the motor. I sounds clogged or something but everything moves smooth, so i really can’t find an explanation.
Video: youtube.com/watch?v=hOnWW2m … e=youtu.be
Does someone knows what this is?
So i tested my motor by this method: youtube.com/watch?v=1U9pf7S_ov4
The LED’s light up and it worked fine.
But while plugin everything back in, i found out that this burned module was the problem:
I switched this one for one of the working axis and my z axis was working again! :smiley:
So those module(s) need to be replaced (the other two are also near dead). But how does this work? Is there something like a warranty for this kind of things? And do i need to go to velleman or to my dealer for this?
I have just experienced the same thing!! The Steppermotor controller burned up…
luckily it seems also here that it did not damage further. I was in the middle of a large print and not near the printer when it happened, but the printer did stop printing and heating and all…
@Eldoras- What did you do about this? Did you contact Velleman? Did you get another chip replacement?
This should not happen during normal use.
Please open a support ticket:
http://support.velleman.eu
