I cant find how to get a replacment z coupler order nr ZC3DJT16 so I decided to go this way . sorry .
I have printet for several hours, but a few days ago, the layers suddenly became different .its like the layers are more wide for each 1,5 mm and narrower in between ,so looked for z ,as a turn is 1,5 mm in up-down position. I see the coupler is broken in one side and is not straigt anymore, so I will need a new one.
can any tell me how to get this sparepart
alex
[quote=“alex1946”]I cant find how to get a replacment z coupler order nr ZC3DJT16 so I decided to go this way . sorry .
alex[/quote]
Your Velleman dealer will help you out.
Other users had some troubles as you for the reason no play between the steppermotoraxis and the
Z rod they are in contact in the middle of the coupler, there must be some space between these 2 parts
as the coupler can take the offset, the steppermotor and the Z rod is never 100% alligned.
