Hello!
When i move my Z-Axis with the Manual method and turn the Encoder wheel a little bit faster the Printer reboot.
Is ther a bug in the firmware? How can i fix this Problem? Pretty annoying when I want to take the printbed down manually to remove it.
Thanks and best regards
Christian
Hi Christian
It’s a known bug with Marlin.
VEL327:
The problem when you move the Z axis down and then the controller resets or freezes is known. This is a marlin bug. We have submitted the bug to the marlin developers. The bug is also present in the other marlin based printers (ultimaker 1, K8200, …) The workaround at the moment is to slowly move the encoder when lowering the Z axis and not turn fast to the point you want the axis to go. If you turn the encoder slowly and you let the buildplatform catch up then the controller doesn’t freeze or reset. When we have a solution a firmware update will be released.
Quote taken from this thread: http://forum.velleman.eu/viewtopic.php?f=62&t=13254
Best regards
Ok then i will turn the encoder slower for further moves.
Christian
