[quote=“pinthenet”]I’d be interested to know how you get on with the LM10UU.
I ordered a set based on the comments here http://forum.velleman.eu/viewtopic.php?f=62&t=16339&p=78013&hilit=LM10UU#p78013 but they didn’t work for me.
Following my z-axis blockage I decided to try again.
The LM10UU by themselves moved very smoothly, but when I added the circlips the movement was already less smooth. By the time I had mounted the bed support & z-stage they hardly moved at all …maybe I misunderstood something.[/quote]
Yeah thats was basicly the same experience i had with the LM10UU replacement vom drylin Iglus, i ordered them also as a recommendation from the mentioned thread and installed all 4 only to finde the z-axis not moving at all of getting stuck in the middle of the z-stage.
In Retrospective i think the Problem was the flexible coupling that Comes normaly with the vertex. Because the drylin are a Little tighter then the lm10uu they seem to Need a bit more force which should be fine for the nema17 but the flexible coupling basicly flexes to much IMO.
At this Point i only replaced the broken LM10UU with one drylin and left the other LM10UU in place because they are still working more or less good and i have a big print order of 150 keychains to complete, but i will look into replacing all 4 after im done with my Project.
Also i replaced the Flexible coupling with a more “stiff” flexible coupling and can only say great Things about this coupling:
ebay.de/itm/221672893797?_tr … EBIDX%3AIT
It has a flexible plastic part in the middle but is more riggid then the original flexible coupling so it works more linear in forms of power Transition IMO.
I can really recommend the coupling, its working perfectly now for about 4 Months.
[quote=“frank.von.thienen”]Hey Markus,
I had forgotten to mention on Twitter, that my bearing have been changed after a few days. They did not move smoothly.
So I got replacement from Velleman
best
Frank[/quote]
Thanks, that was exactly my Problem only that my bearings worked for almos 1 1/2 years without a Problem. But now they are replaced and working like a charm for now
