So the Z-Axis stops and stutters when homed or manually jogged. I’ve cleaned the rods and bearings from any dirt etc. I have tried taking the z coupler off the stepper motor to see if it still does it and it does. So I don’t know what could be causing it.
[quote=“to3dornottobe”]Sorry, didn’t read OP. I have a problem with Z while jogging manually, firmware crashes and reboots.[/quote]That’s a bug in the firmware. If you move the Z axis too quickly the printer crashes.
Ok I think I’m running out of ideas.
The flex connector Z motor to the shaft.
Is it broken?
This can happen if you run the bed all of the way to the bottom without homing it first.
Don’t ask how I know.
Lol
