Z-axis stabilizer
Here’s my latest ‘project’: a ‘z-axis stabilizer clamp’ (or whatever you want to call it;)).
The clamp can be used in combination with a plain 608 bearing to help stabilize the z-axis.
I tested the result of course but I have to say, for me the quality improvement is barely noticable.
But, it removes the vibrating sounds that the axis produces during z-axis travel and I like that too ;).
Please keep in mind that this mod could potentially harm your z-axis if it is not aligned perfectly so make sure it fits your printer nicely as well.
File can be found here: thingiverse.com/thing:635751
Have fun!
Erik
Excellent, I was planning on making one of these aswell. I’ll give yours a try.
Could you point me to a good/not to expensive website or store that sells these bearings?
I’m not sure what to look at when buying a bearing.
Best regards,
Danny
I believe this is a standard bearing that is used in inline skates as well, might find them even in a toy store around the corner ;).
Just look for a so-called ‘608’ bearing. The 608RS is a bearing with standard rubber sealings. The size is 8x22x7mm.
Erik
Ok, i’ll take a look at it. Thank you Erik.
Best regards,
Danny
made one of these and it works gr8 very good idea for the mounting options the idea of drilling holes put me off making one , but this fits like a glove
gr8 work
Thanks @h60, great work. Printed with 0.2mm settings and fittings for the frame + bearing are both perfect.
What modelling software are you using? Rounded edges look like a pro finish.
I have been using AutoDesk 123D Design.
Best off all, it’s free :)!
Erik
Looks good. I’m thinking about buying this printer and this is one of the things I would improve.
Would also be nice to make it in black and fit it to the side, lige the other parts
