Yes the movements are a lot smoother and there’s no backlash anymore.
A second Z axis is not mandatory as the result is already very good with one. But with 2 the movement is even smoother and perfect. And the extruder arm stays horizontal.
[quote=“raby”]Yes the movements are a lot smoother and there’s no backlash anymore.
A second Z axis is not mandatory as the result is already very good with one. But with 2 the movement is even smoother and perfect. And the extruder arm stays horizontal.[/quote]
What he said. I’ve got absolutely no backlash anymore, and the arm is completely rigid. Result in print quality is noticeably less irregularities on surfaces.
I also upgraded to 10x2 and I installed a second axis. The second axis just makes the whole z-arm more rigid but the print-quality did not improve that much…
Neither did mine except that now I can print higher objects (20 cm or even 22) without any problem which was not the case with the stock spindle. Above 10 cm the movement began to be irregular with the Z axis vibrating like hell.
