is this something i should be worrying about, there is a pronounced wobble.
the z screw is bent.
i know these aren’t precision threaded bars, will this affect printing in any way?
many thanks for your time.
Gary:)
Gary:)
Is your printer finished? Have you tried printing anything yet? A little wobble is common, it’s difficult to assertain what one person understands to be “a little” or “a lot” vs another person.
2 to 3mm wobble.
printer is finished.
issues with …
getting z stop accurately tuned in, see other post.
getting heated bed flat.
counter sunk screws on heated bed protruding, will they impact on nozzle at 0.25mm?
cheers,
gary:)
Use the thumbscrews underneath the bed to raise or lower the 4 corners of the bed appropriately. If the bed is bulging in the middle you can detach it and make the holes for the screws a bit bigger (3,5mm or 4mm).
Put the nozzle at 0.25 mm, then move the bed by hand to see if they impact the nozzle.
I would not worry about the Z-axis wobble, I doubt this will have any adverse effect on your print.
some video of the issue.
