Z axes
please help
z axes seems to be moving 1/2 the distance stated on the read out?
so my printed parts are 1/2 size in Z i.e. should measure 10mm but only measures only 5mm the read out say 10mm.
what do I need to adjust?
Mike
Hi there was an issue about X/Y movements 1/2.
I could not find it anymore, maybe you can search for it.
Might be same issue only in a different direction
Best
Frank
Try swapping the Z stepper driver with another (X or Y) and check if the problem moves to the other axis.
thank you for replying!
I found out that the issue was a bad Driver board its work well now!
