So i have redesigned a new fan duct for the mainboard cooling. Using a 80mm fan mounted underneath the frame. Because of the limited height under the frame, the fan has to mounted in an angle.
Someday i might try to print it on the side as suggested.
Here is a picture of the part installed
[/quote]
Does look pretty good!
I see your control wheel thing is pushed on all the way, but on mine I had to apply a lot of force to get it on even a little. I’m scared of breaking the PCB, so do you have any tips on how to get it on?
[/quote]
I see your control wheel thing is pushed on all the way, but on mine I had to apply a lot of force to get it on even a little. I’m scared of breaking the PCB, so do you have any tips on how to get it on?[/quote]
I drilled the control wheel with a 6mm drill, now it is a loose fit, so i added a drop of glue.
[quote=“Fer”]I drilled the control wheel with a 6mm drill, now it is a loose fit, so i added a drop of glue.
I would try with a 5,5mm drill if i where you.[/quote]
Thanks! I’ll give it a go when I’m back to my printer at the end of the month. If I can get it off, of course!
