The wires that connect to micro switch sometimes will hang out and rub on the frame in the back.
When they hit the cable ties it will cause them to move and break the solder joints.
If you have this happening resolder the connections (remember the outside post) and then cable tie the wires to the post that holds the switch so they don’t hang out anymore.
