Y-motor gives wrong -movement
Hi there,
I tested the printermotors and stops, but I have a problem when I give the manual command -1 or -10.
It doesn’t move the logfiles show the next:
echo: endstops hit: Y:6.77
After I send the command again it gives:
echo: endstops hit: Y:6.76
Al the other movements are correct also the +1 or +10 manual movements of the Y motor are correct.
I changed the plug from the X-motor to the Y-motor nd than it works correct, so it can’t be the motor.
What should I do?
Thanks for your help.
Did you try to send it to the Y home position?
Manual control upper right corner Y with the house next to it.
You may also need to double check the wiring for the Y end stop switch.
If the Y endstop is being hit while it’s actually not, then endstop probably has a bad or loose contact.
You can try uploading the following firmware to the mainboard:
velleman.eu/downloads/files/ … RLINV2.rar
You can use the last chapter of the online manual to know how to do this.
This is a new firmware we will officially release when the LCD/SD CARD board is released but it is possible it will solve your problem.
(it handles endstops hits differently)
[quote=“VEL327”]You can try uploading the following firmware to the mainboard:
velleman.be/downloads/files/ … RLINV2.rar
(it handles endstops hits differently)[/quote]
Well the link is not working…
http://www.velleman.eu/downloads/files/k8200/firmware/FIRMWARE_K8200_MARLINV2.rar
