My printer suddenly stopped working. All commands to the motors give no reaction. Thee extruder doesn’t reach the set point and will oscillate about 10 degrees below set point.
The rest works, heated bed reaches set temperature and the fan reacts to input.
Yes and I can control the fan + speed and set temperatures. The fan works, The bed works, extruder heats up but doesn’t reach set point and Steppers don’t work.
Could there be something wrong with the circuitry / motor drivers?
[quote=“ichbinsnur”]That part is the 5v regulator for the digital logic.
If it doesn’t get too hot to touch it should be ok. Whereas about 50°c sound a bit warm.
Try to remove all the stepper driver boards and then reinserting them one by one, to see if one of the stepper modules causes the trouble.[/quote]
I’ve tested all every driver board, no success. The steppers work though, when i put a voltage on their pins, they lock into place. With the board connected, the steppers can move freely.
This might not be it but it’s worth checking.
In the printer settings check to make sure Reset on Connect is set to Disabled.
Mine was changed for some reason after it was running.
M999 generally means that the the extruder or bed temps are out of line.
Either at 0C or 700C
If you have 0C you have an open for that thermistor.
700C means a short.
You may want to try to shutdown Repetier reset the printer and start everything up again to see if the clears the error.
