My X-axis of my vertex K8400 shifts very quickly in each print. I checked the pullies, but they all are tight. They are secured with two set screws each, and they are not loose. I have tried multiple levels of tighness on my belts, but it all doesn’t make a difference. What should I do next? I am leaning towards a faulty motor, but I don’t know…
I did a total realignment, it did help solve the x-axis issue, but now the other axis shifts (y-axis)… I had one loose pully because one thread was stripped, but after making sure it is tight again still getting the problems.
i have the new pulleys, I did the alignment procudure twice alredy but still getting problems. I noticed that the x axis linear rod for the tube bearing (not iglidur) is pretty stiff… do i think that is the problem at the moment
[quote=“Tyutje”]I noticed that the x axis linear rod for the tube bearing (not iglidur) is pretty stiff… do i think that is the problem at the moment[/quote]I could be. There were some reports of rods varying in diameter and bearings too narrow (but in that case you usually can’t get the rod through it).
