X axis shift - first few layers only
For a while all my prints were fine, but since yesterday evening I am getting x-axis shifts for the first few layers only (0.2-0.5mm) . The rest of the shape prints well.
Anyone has the same issue? Advise?
problem solved
cause : glass plate moved a little sometimes
I printed a custom piece that blocks the plate in the x-axis.
I will post this piece later on thingiverse with some more info.
You can try to bend the little metal clips a bit so they press harder on the buildplate.
