X axis belt jumping
Hello all,
I completed the build of my K8200 yesterday and went through the calibration this morning. The outline prints precisely but when the printer is filling in the x axis occasionally jumps, causing the infill to continue about 2cm out of place. I have tested it with multiple downloaded files of different items but they all appear to give the same issue.
Things I have tried:
  • Re-seat x axis motor to ensure it is straight
  • Re-adjust x axis belt and adjusted tension
  • Changed x axis motor to 0.55 V
  • Removed the heat bed to adjust the x axis linear bearings, ensuring the axis doesn’t snag
I’m stuck for ideas to try in an attempt to resolve the issue. Any help will be much appreciated, hopefully I can get it printing soon.
p.s. I’ve got a few bits to do today, but hopefully later I’ll get a chance to take a video of it.
Cheers
Jim
Did you Pay attention to the pulleys too? Mabe one of them slips on the motor axis.
Video would be a great help.
Check the pulleys on the other end.
Make sure they are not to tight and can turn freely
Thank you for the suggestion. I will check that the pulley isn’t too tight.
I won’t be able to check for a couple of hours or so, but will let you know how that went as soon as I can along with a video.
Cheers
Jim
Update:
I have adjusted the pulley and that didn’t solve my problem so I decided to go through the calibration steps again just in case I missed something. It turns out that the X-axes motor controller was set to 0.7V so I changed it back to 0.55V and all appears to be working perfectly now.
I must have missed the X-axes motor trimming when going through the set-up first time round.
Thank you all for your input, it is much appreciated.
Cheers
Jim
Hey, nice to hear it works now.
Happy printing!
[quote=“ichbinsnur”]Hey, nice to hear it works now.
Happy printing![/quote]
Thank you. It’s an amazing feeling seeing a 3d printer work after spending a couple of days building and calibrating it. I’m looking a bit like a Cheshire cat now, just need to work on my 3D CAD skills now :smiley:
Thank you
Jim
Glad to hear it’s working.
Happy printing!!
