So i started up my printer yesterday after it had been unused for a few months and something seems to be wrong.
When i home Y it moves away! from the endstop a bit then changes direction and goes to endstop then stop, when i after that manually moves the Y axis either with LCD controller or repetier host the axis only moves in one direction away from endstop regardless of which way i tell it to move, explained: say it moves in + direction, i tell Y to move +10mm it moves +10mm but if i tell it to move -10mm it moves +10mm.
The X just locks up when it tries to move and the motor hums, i have changed the motor controllers and they are not at fault, neither are the motors.
The Z axis works like it should.
Anyone know what this can be if it’s not a faulty controller board?
Edit:
Found post mentioning that you should compile with arduino 1.0.4 since later version compiles wrong and y does not work, i did a new firmware flash when i fixed the Z axis and i did that with 1.0.6 so i will try 1.0.4 later.
My problem is confirmed to be related to arduino compiling.
Using 1.0.4 i get:
Binary sketch size: 104 484 bytes (of a 258 048 byte maximum)
And the printer works like it should all homing, movements and endstops works.
Using 1.0.6 i get:
Sketch uses 92,646 bytes (36%) of program storage space. Maximum is 253,952 bytes.
Global variables use 3,867 bytes (47%) of dynamic memory, leaving 4,325 bytes for local variables. Maximum is 8,192 bytes.
And the printer behaves like i explained in first post.
I redid the firmware a few times on the two versions and got same result so for me this is confirmed.
I have not looked into if there are any new settings in arduino 1.0.6 that should be changed for this to work though, i’m fine using 1.0.4 for now.
