Www.k8200.eu not displaying properly
Many of the website style sheets are missing and the site no longer renders properly so you can’t see the instructions or download the PDF’s. See bottom of this post for console output from Safari.
So now I’m stuck and can’t do any more building this weekend.
Does anyone have the PDF’s uploaded anywhere?
The link to forum.velleman.eu/code.php to the captcha to be able to register has to be done by copy & paste. Is this really necessary? It’s a huge PITA for non-technical users!
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (bootstrap.min.css, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (lightbox.css, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (framework.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (bootstrap-responsive.min.css, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (jquery-ui-1.10.3.custom.min.css, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (bootstrap.min.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (jquery.cookie.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (jquery.smooth-scroll.min.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (lightbox.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (jquery-ui-1.10.3.custom.min.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (shared.css, line 0)
I have the same problem as you. (Have tried to open the instructions in both internet Explorer and Chrome on two different PC’s)
Found the instruction manual for download here:
esr.co.uk/education/index.htm
Thank you for reporting this. I’ve restored the K8200 website to its original state. I will inquire with our web developers on monday about what went wrong.
The captcha on the forum helps a lot in keeping spammers away. We very seldomly get a complaint about not being able to register, and when we do we gladly create and activate an account for them.
Sorry for the inconvenience and enjoy building the printer!
As in, which one of them moved/deleted the scripts!
Thanks for getting it up so quickly!
I’m not objecting to the captcha, I’m wondering why you have to painstakingly copy the url to put in another window - what’s wrong with making it an actual link?
[quote=“nmccloud”]As in, which one of them moved/deleted the scripts![/quote]Indeed, which one will get spanked
[quote=“nmccloud”]I’m not objecting to the captcha, I’m wondering why you have to painstakingly copy the url to put in another window - what’s wrong with making it an actual link?[/quote]Even the most inexperienced computer user will know how to copy and paste a small piece of text, and it does not require anything special (javascript, etc).
