WSMI8115 – LCD backlight lights on but nothing else happens
I bought this kit last year (2022) in May but have only just now assembled it.
When I connect the 9V battery and then push the button, the backlight of the LCD lights on but nothing else happens.
As I am not having a lot of experience with soldering, I have attached some pictures of the result. So, I would appreciate if some good soul could have a look at these.
Are there any other reasons for this kit not working, apart from poor soldering?
Thanks in advance for your support.
Hi!
Thanks for the clear pictures! Appriciate it
You did really well with your soldering!
I do see some cold solder points, though. Just re-apply heat to the pad, and adding solder will fix these.
Just took some examples.
Please report back with your findings
Regards
VEL337
Thanks a lot for your assessment.
I really appreciate.
So, I applied fixes to some of the joints.
But without success.
Ie, when I connect the 9V battery and then push the button, the backlight of the LCD lights on but nothing else happens.
In the meantime I figured out that in the past this same problem occurred to several outher user. And in those cases replacing the CD4050 IC seemed to have solved the issue.
So?
Yes that’s correct.
I just wanted to check the soldering to exclude any soldering issue.
If you could DM me your address I’ll arrange a new IC for you.
VEL337
Thanks a lot.
But when I try to send you a DM, I get “An error occurred: Sorry, VEL337 is not accepting messages at the moment.”
Am I using the wrong method for sending DM´s?
Please use the support ticket system on our website https://www.velleman.eu
Use the customer care button on the bottom right corner.
And reference this post in the ticket.
VEL337
Done
The reference of the ticket is 10040
Best regards
