All the lights stay on constantly, and the star doesn’t respond to sounds. What should I check for?
Main Issue: The manual/instructions are difficult to follow. Step 9 seems to imply that the flap (third leg/casing) should be grounded.
Solution: Grounding the mic casing resolved the issue, and the board functioned as expected.
Suggestions for the Developers:
- Improve Step 9: Make it clearer and more precise, as it’s crucial for proper functionality.
- Clarify Step 8: Provide more detail or explanation.
- Avoid Duplicate Step Numbers: Having two Step 1 sections is confusing, especially for beginners learning soldering and electronics. A suggested sequence could be:
- Step 1: Jumper
- Step 2: Resistor
- Step 3: LEDs
- Enhance Copper Thickness: The current copper thickness is too thin, making it prone to overheating and breaking. Increasing its thickness would improve durability.
Thanks for a fun project!
