I’ve been having some great fun with the K8200 lately. However, for some reason I don’t seem to measure the correct temperature for the heated bed. I would like to hear your opinion on the following:
I have the standard heated bed with a 100k thermistor soldered on the bottom. When I turn on the heated bed, I am measuring realistic values and the bed reaches temperature fairly quickly. I confirmed my measurements by placing another thermistor on top of the bed, and attached it to the hot end thermistor pins for readout. Everything OK so far.
However, when I start my heated bed while I have a glass pane (3mm thick) on top, I am not able to reach temperatures of 45C or higher. However, the glass pane is incredibly hot, to hot to put my finger on for more than a second.
Is there a common explanation for this problem? Does anyone know a solution?
So, the problem is back and I managed to do some measurements:
I have measured the temperature in the center to be the same temperature as my heated bed NTC was measuring: about 45 degrees Celcius. However, the temperature at the sides of the board quickly increases to 80+ degrees Celcius… that’s when I turned the bed off to save my bed.
Now, it turns out that the problem was gone because I used insulated clamps to hold my bed + glass pane. However, when I put screws through the holes, the problem starts. I found that the screws make an electrical connection between the frame holding the bed and the power supply, burning up a decent amount of my power…
Hy,
you should check the wires from the bed to the main board, maybe you have a short circuit ?
I had same problem, then I change original 4 mixed cable by a silicon 0.75 mm cable, the heat bed reach much more rapidly high temperature than the original conection.
Thanks might do this as well. Found some tiny scratches on the bottom of the heated bed, making a connection with the frame and thus shorting the circuit
