When I slice a print with repetier (cura engine) using the single head setting and selecting the second extruder, the g-code contains the temperature settings of extruder 1 for extruder 2.
It does print with the second extruder (with a offset). When I select extruder 0 for support (even when not using support) the temperatures are correct (but the 0 extruder is heated while not extruding and will clod).
Is anyone familiar with the problem?
