I just have my k8400 and finished a small print, but the dimensions are ± 0.3mm off. Its a funnel, both inside and outside dimensions are to small.
Drawing - print
- out 24mm - 23,7mm
- out 27mm - 26,7mm
- in 17mm - 16,5mm
After some searching here I already found that it kinda normal that the inside diameter is to small. If so, is it always the same deviation?
Also my settings have to be changed a bit for what is see: retraction, temp and extrusion. But will this help for the outside dimensions?
Thanks.
