WPM404 : Vin close to Vout
I am looking for a voltage regulator with a constant Vout = 12VDC to use with a 4s LiPo battery as input. These batteries have a voltage range of 12.8-16.8 VDC.
I was wondering if I could use the WPM404 and how it would behave with a Vout close to Vin (as low as 0.8V) ? I did not find any indication on the minimal voltage difference in the documentation.
Thank you.
I fond my answer on a test of the module here :
https://lygte-info.dk/review/Power%20Adjustable%20buck%20converter%20LM2596%20UK.html
It seems that no. With a charge, below Vin = 16 VDC, Vout is between 11-12 VDC.
