So we have a school project to assemble a k8200 printer and print a model.
we built the printer, we used the manual on the internett, er did everything like it was in the manual.
when we connect the printer to the computer with Repetier the printer blink twice (red and green) and then it says on repetier:
System com error: IO.SYSTEM
something like that, we cant seem to find the problem, when we try to start it, it says heating extruder but it does not get warm.
please provide some more info. Which operating system are you using? Which version of Repetier Host? Was the installation of the USB drivers successful?
Also, please check the power supply, just to be sure. When the printer gets only intermittent power, that would cause some issues with communication. Do you have stable 15 V on the power input screw terminal?
we are using windows 7, the repetier version is v0.84. we installed the driver from the instructions.
The power supply is ok, and its connected to the screws.
the fast version: get rid of the 0.84 Repetier Host, instead install the 0.90C. Use the same settings for the Printer Settings, K8200 profile like shown in the instructions, but make sure the new option “Reset on Connect” is set to Disabled.
Try again and if it doesn’t work, copy & paste the log output or any error message there might be.
It said printing layers and counting up to 114 layers, when it was finished it said “print job finished” but… the printer didnt do anything, it was just standing still. does anyone know what the problem may be ?
