Hi, can you explain the wiring of the vma431, thanks
You can find the instructions in this link.
https://www.vellemanusa.com/downloads/29/vma431_a4v01.pdf
I always have the instructions, but I want to know, the wiring, please,
If you are going to use the sketch in the instructions
VCC ==> 5volts
GND ==> Ground
Sig ==> 0
Thanks Wrong_way, can you explain NC pin ?
NC ==> ?
NC= No Connection.
Hope that helps.
Is the polarity changable? Can I reverse magnetic north vs. south by reversing the voltage?
Hello @seandoyle,
It can’t be done via reversing the voltage on the VMA431 module.
But if you interchange the bleu wires of the electromagnet than can you change the polarity.
This can be changed via H-bridge aslo, see this topic on forum researchgate.net: How to make an electromagnet that changes its polarity after a fixed interval of time? (researchgate.net).
Best regards,
Velleman Support
