Wires to NTC
I was wondering what the wire is called to the NTC, its not a normal wire because it need to stand against the heat.
And also whats the name of the white tubes you need to put over it?
Thank you
I don’t understand your question.
Do you speak about cable chain ?
Hello Citystars,
i am no shure but i think the white tubes called in Germany “Fiberglas Schauch”
[quote=“eytec”]Hello Citystars,
i am no shure but i think the white tubes called in Germany “Fiberglas Schauch”[/quote]
Thank you!
With a little bit or research i came across this page:
techflex.nl/extreem-temp-c-4 … anguage=EN
