I have just upgraded a new Windows 8.1 machine to Windows 10. K8200 no longer works. (It did before upgrade)
Repetier connects OK - ‘Idle’ then in a few seconds goes to ‘X Command Waiting’ (X is a number and varies) Everything still works OK on a Windows 7 machine. Could it be a driver problem - are win 10 drivers available?
Have you already tried to reinstall the driver?
Maybe it got corrupted during the upgrade.
The controller uses an FTDI chip, so windows 10 should also be able to find the correct driver online.
Thanks for quick answer. Did windows update. Still no joy. Unplugged power supply and reconnected. Able to move axes. Win7 machine with Repetier 0.86 starts Ok power on. Cannot test print before weekend.
Problem no longer. It was a minor irritant compared with other problems with feed and quality (see Feed Erratic in Issues while printing) These I solved with the help of other contributors (particularly Dr Vegetable, Wrong Way and Fitchie) and replacing Drivers on Extruder and X and Y. Fitted DRV8825. This allowed increased current to the extruder motor and finer control of X and Y. At the end of all this the connection problem had disappeared.
