I have a K8031 scope which was working fine on Windows XP. I have just upgraded to Windows 7 (64bit) and have loaded PcLab2000se V3.1. When I try to run PCLab2000se I get the error message “Cannot open the DriverLINX driver. Please run INSTALL_DRV.EXE to install driver”. I am running PcLab2000se from an administrator account.
I still get the same error message even after I have run INSTALL_DRV.EXE from an administrator account.
I have tried deleting DLportIO key and rebooting but I still get the same problem. I have also tried loading PCLab2000se on another machine which is running the release candidate version of Windows 7 and I get the same problem.
That’s a bit of a problem. I don’t want to down grade my main PC to 32 bit so I guess the only way forward for me is to put XP on an old machine and use that for my scope. Are there any plans to release a 64bit version as most new PCs are 64bit?
I think there will be no 64 bit release for the parallel port connected oscilloscopes.
The new USB connected oscilloscopes PCSU1000 and PCSGU250 run on 64-bit Windows 7.
The 64-bit XP seems to be more problematic case: viewtopic.php?f=3&t=3563
