Will this work on my mk139
will it work i f plug my velleman mk 139 on a led 12 DC 6 A adaptor?. because i want a 5 M led strip 120 leds a Meter. work on it.
thank you
Relais say it can handle more. But i saw on ather forums that it gave problems.
I think 6 amps is more then what the kit is rated for
You will need to use an external relay.
The relay may be rated for it but the board is not.
[quote=“Wrong Way”]I think 6 amps is more then what the kit is rated for
The relay may be rated for it but the board is not.[/quote]
thank you.
