You should search the this board.
Others have added a heated bed with a separate power supply (24 volt) and a power expander.
The control board still uses the 15 volt power supply that will run both print heads and the bed runs off of the 24 volt power supply and is controlled from the mother board.
[quote=“Wrong Way”]You should search the this board.
The control board still uses the 15 volt power supply that will run both print heads and the bed runs off of the 24 volt power supply and is controlled from the mother board.[/quote]
I’d like to use one power supply the 24V, therefore i’m searching for the converter so i can power the mainboard, heatbed and rasberry with the 24V powersupply.
