I someone has an experience trying to pre-amp an Mike Ribbon type.
I don’t see wich kit could help ?
Some feed back are wellcome.
Thanks.
Julien
Thanks.
Julien
We have no experience with a ribbon mike.
What are you trying to do ?
Output level of the mic ?
Required amplification ?
Output impedance of the mic ?
Required freq. range ?
Hallo ;
It’s for voices-over, I’ve been trying to get the sound of it with a Shure XLR to USB on a MAC with verry less response.
So that’s why I need to get this mike Pre-Amplified.
Thank you for your help.
Coles 4104 Commentators Ribbon Microphone Technical Specification
Features :
Frequency Response 60 Hz to 12,000 Hz
* Better than 30 dB average discrimination between voice and background noise.
* Provides speech of broadcast quality completely free from breath noises.
* Flat frequency response at the controlled talking distance.
Frequency Response
* 60 Hz to 12,000 Hz
Impedance
* 300 ohm
Sensitivity
* -50 db W.R.T. IV/Pa
Equivalent Electro-magnetic hum pick up
* Less than 0.0002 dynes/cm² equivalent acoustic input for 1 milligaus at 50 c/s
Distortion
* Less than 1% at 120 dB SPL
Connection
* By means of an XLR 3 pin plug - Pin 1 screen - Pin 2 positive - Pin 3 negative.
something like this might work
Most likely, this kit will do the job:
Thank for your words.
The Impedance of the mike is = 300 ohms.
When I’m taking the “PREAMPLIFICATEUR MONO UNIVERSEL” K1803
Link "http://www.velleman.eu/distributor/products/view/?id=8897
I should change the Impedance at the input .
Does someone could help me to modify the kit to getting it working on a Mike with 300 ohms ?
Thank you
Most likely, no need to adapt impedance.
