Hi guys,
After I while I started to get Z banding on my prints and having upgraded the Z system to eliminate mechanical issues I started to look at the programs. Looking at guides on the internet calibrating the extruder I noticed my printer extrudes 42mm of material when I ask for 50mm, showing the E steps are wrong. I updated my eprom to 705 steps/mm to get 50mm correctly.
But I then wasn’t sure what I should change in Slic3r to reset this. I started by altering the multiplier from 1.15 to 1 but my prints seemed worse, but I took the next step to calibrate wall thickness by printing a hollow cube 1 perimeter thick. Asking for 0.42mm would give me 0.51mm, adjusting the multiplier to 0.82 gave me a perfect sized cube with walls and overall sizes correct. However my layers would delaminate easily and running some common parts off resulted in awful prints, I was obviously not extruding enough material.
I was sure the multiplier of 0.82 should be left as close to 1 as possible and reset this, adjusting my perimeter % in Slic3r to try and get the same perfect sized cube. After playing for this for a few days I gave up and reverted back to the 600 steps in the eprom and default slic3r setting which work very well.
My question, has anyone else done this and got it to work?
I would still like to calibrate my printer close to perfection if I can.
Andy
