i’ve got an iMac and i would like to know witch file configuration Slic3r i must take ?
I think it’s this one :
K8200-PLA-STANDARD_NEW.INI
and i would like to know if this is ok with Repetier 0.56 and Slic3r 0.9.10b for my iMac ?
Yes, Repetier version 0.56 works fine as far as I can tell. (I actually work with it.)
Do the setup as normal “k8200_pla_standard” (you can name it as you like) and fill in the values given by velleman.
Should work out-of-the-box.
Ok thanks for informations
I will try it when i will finished to mount the k8200
