I downloaded the host version1.6.0, set the Comms port and downloaded the drivers and everything runs fine under manual control although the screens are slightly different to those in the construction manual and I could not find several fields for setting.
I then saw your notification that there was an “all in 1” host, (drivers the lot- all in 1 download) that matches the manual so I downloaded that. (v .095)However, even though the Com port setting is the same, there is no response to manual control. Any ideas or should I stick with v 1.6.0?
Cheers,
Andrew.
