I print with 3mm white PLA, most often with succes. I post this because I have some questions about bed and extruder temperatures.
This is how I work: Every time before a large print I check and if needed, recalibrate the Z-axis at each corner of the gp8200 glass printing bed. I do this accurately with a piece of paper. Than I clean the bed using a warm cloth and handsoap and I dry it with a towel. After I cleaned the bed I heat it using the bed heater itself and I also use a hairdryer as I am yet to install a 24V supply (takes forever to heat the bed) when the bed is warm I degrease it using 70% cleaning alcohol. Moments before I hit “print” I apply a gluestick for the much needed extra adhesion, I used to use hairspray but this would drop the bed temperature with about 10C so I always printed at 50C and hairspray cost more €€€
I still use the stock extruder with 0.5mm nozzle
For the first layer I print with about 30mm/s and slightly more PLA than the other layers. I attached the glassplate with schotchtape on the corners, had some issues with the clips.
so far I learned that:
- If I only miss 1 spot with the gluestick an object can start curling upward.
- Nozzle height listens very closely. Slightly to high results in bad adhesion.
- really need to get me a 24V power supply for the printbed.
Though most of the prints come out ok, I still can’t leave the house during a print. Today I finally fixed the stock Z-axis which would skip a step occasionally (lost many prints because the extruder would slam of an object). If I now get the bed adhesion techniques under control. I can go to school in peace once again
What I want to know are the temperatures which give better adhesion to the bed. I know I can print with 50C and 60C for the bed and 190C-210C for the extruder head.
- How does bed temperature affect adhesion and what would be the optimal bed temperature be for white PLA 50C, 60C, or even 70C? (doesn’t a hotter bed make the PLA softer that it wants to curl up more easy??)
- During printing should I let the bed cool down to below 50C, 50C or just let it be at 60C.
- I print normally with a 190C extruder temperature because you know it works…, does a higher extruder temperature affect bed adhesion or does it affect print quality and how?
- is 30mm/s slow enough for the first layer or does it help alot to make it even slower?
If anybody knows any of the answers, I would be very gratefull. (if you number the answer(s) like my questions I would be even more gratefull
