Which potentiometer adjusts the feed motor?
Nearly there!
X/Y/Z All working fine but the motor on the extruder is not coping without manual assist. I have backed off the tension spring on the filament feed and would like to increase the voltage on this motor. Which potentiometer is it and is it OK to have 1 motor at a higher voltage than the rest?
Cheers,
Andrew.
you could try it.
normally it would be designated with something like E-MOTOR
Got it- thanks Brecht!
The best adjustment for all of the Steppers is 0.55
If you go over 0.6 the drivers will over heat.
